Feature Request: ConvertDots grouping behavior
I’d like to request a change in behavior for ConvertDots:
Currently, if you convert a group of dots to text, the new text blocks are added to the same group as the dots. I’d like to request the option or default change to output the new text objects as a separate group from the dots. Since they are created in the same place, it’s impossible to easily select the newly created text when I need to keep the inputs. It would also be great to be able to convert to a TextObject, not just a TextBlock.
That seems like a bug - thanks for the report.
RH-63762 ConvertDots: make a new group
RH-63762 is fixed in the latest Rhino 7 Service Release Candidate
