Selecting dot freezes beta
Not sure if the grouping has anything to do with it, but the most recent beta is freezing when I try to select a grouped text dots, and also when I try to ctrl-shift-select one dot from the group. Thx.
bug.3dm (193.2 KB)
Rhino 6 SR0 2016-12-6 (Public Build, 6.0.16341.12271, Git hash:master @ 876bc66685a133f2c9a1c5db09da3c44398d15ec)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
GeForce GTX 1080/PCIe/SSE2 (OpenGL ver:4.5.0 NVIDIA 369.56)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: None
Anisotropic Filtering Mode: None
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 10-9-2016
Driver Version: 21.21.13.6956
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” n/a
C:\Program Files\Rhino WIP\Plug-ins\WebBrowser.rhp “WebBrowser” n/a
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit” n/a
C:\Program Files\Rhino WIP\Plug-ins\RhinoScript.rhp “RhinoScript” n/a
C:\Program Files\Rhino WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor” n/a
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Rhino Render” n/a
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” n/a
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI” n/a
C:\Program Files\Rhino WIP\Plug-ins\Alerter.rhp “Alerter” n/a
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” n/a
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” n/a
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement” n/a
Hi Hannes - so far OK here - did you test with the exported dots file, or only in the original file?
I tried it both ways.
I can confirm this. although it does not happen all the time.
possibly somehow dependent on the display mode?!
Windows 7 SP1 (Physical RAM: 48Gb)
GeForce GTX TITAN X/PCIe/SSE2 (OpenGL ver:4.5.0 NVIDIA 376.19)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Driver Date: 12-1-2016
Driver Version: 21.21.13.7619
Total Video Memory: 12 GB
C:\Program Files\Rhino WIP\Plug-ins\SolidTools.rhp “SolidTools” n/a
C:\Program Files\Rhino WIP\Plug-ins\RPC.rhp “RPC” n/a
C:\Program Files\Rhino WIP\Plug-ins\AnimationTools.rhp “AnimationTools” n/a
It is certainly slow in Arctic but not frozen…( which just seems wrong, somehow).
Rendered slows down as well but neither seems related to grouping so far…
Still poking…
@hanscad - can you tell if this is related to the current display mode in your case? Doyou get the same behavior in all display modes?
It does not seem to be related to display mode.
Hi Hans - thanks - I cannot reproduce this here in your file nor in any others so far. I’m at a loss … @stevebaer - do you have an idea? Looks like at least two users, @hanscad & @dk2079 are seeing this:
Actually I just tested again and found that I’m not seeing this behavior today, after yesterday’s new version of the beta. I had a freeze from this yesterday on the same file, so it must have gotten fixed in the mix.
Just the answer I was hoping for - thanks for the update!
Sorry I spoke too soon, I did get another freeze.
Does this freeze only occur when the properties panel is open? If the layers dialog is open instead, do you still see the freeze?
I’m having trouble duplicating the error again right now, but I always work with both the layer and properties panels open.
still freezing with the last WIP.
I have properties and layers open all the time
I can select them successfully if I disable “text” in display, and select via right click in layer tree, and delete them. (they sometimes appear by them self after bool operations “!”)
