Would be cool to be able to (with stuff like a SubDFaceEdgeVertexToggle ish) be able to do bigger selections, make them UV seams, then maybe manually going in and removing a few. (instead of the reverse).
So outside of the uv editor/unwrap, so potentially an additive and a variant that removes the seams.
edit:
hmm assuming that doing any edits always destroys the seams, having this command would then make a custom plugin viable which would save seams manually/some other extension way, then just call that ‘SelectionToUVSeams’ command to send the data over to the unwrap or something like that.
Let’s see if I got this correctly. This sounds like something that is probably requested earlier too.
So you would select a set of faces on your 3d model.
Then tell Rhino to make UV island from that selection.
Then you would add and remove seams by clicking on edges.
Adding seams is possible without unwrapping but the islands would of course be connected. Removing seams however is not generally possible without moving and shaping islands which is essentially a partial unwrap of the 3d object.
First is a feature generally in rhino that can swap a face selection to the edges, or to the points. (subd can do it as a toggle, but it wouldbe very nice if all geometry kinds could selectively do it, in many cases its very convenient to box select a thing, then ‘to points’ and you get the vertices).
the other thing is an ‘api’ or functionality to mark/unmark seams, since arbitrary selections (like mentioned) can then be used to mark or unmark.
instead of having some bespoke special “you have to click these things when in this mode” which effectively is arbitrary selections carried over as ‘seams’ but worse in my opinion.
when i say adding/removing seams that does not imply any auto unwrap, i ofc assume a manual “unwrap” would have to be called, as the intermediary step of weird selected edges does not result in unwrapping that makes sense.
but since you’re asking does that imply that it goes into a ‘is in unwrapping state’ and then it HAS to exit that, then it gets unwrapped? it doesn’t have like ‘data of the seams’ and then it just uses that for the unwrap?
