FBX import with textures
What are the possibilities for importing FBX files from 3dsmax into Rhino including textures? I can’t get it working. I need some help.
Leslie
Hi @Leslie_van_Berkel
Pretty hard to tell without a file to test. Don’t have access to 3dsmax, but FBX from Blender comes in fine with textures intact. Either post the offending FBX or a test file that shows the problem (just a simple box with the texture not showing up is fine): maybe check to see if the export options in 3dsmax has textures turned off (it used to be called Embed Media, but I haven’t used 3dsmax for a while, so it might have changed).
HTH, Jakob
Hi Jacob,
I found the solution! 3ds max has ‘standard’ materials and ‘physical’ materials.
When exporting an FBX you need to use the ‘standard’ legacy materials.
Leslie
