if I import FBX data, than the objects are unwelded. I tried to enable and disable unwelding. Is it a bug? Or wouldn’t it help to get an option for welding?
Are you sure you didn’t have Flat Shading checked?
No, because _weld helps.
Can you share the bottle fbx? I couldn’t reproduce with the sphere model.
Attached one of the files from my client.
fbx.rar (5.1 MB)
It looks like the model isn’t exported properly. When I bring it into blender the bottles are also faceted.
I suppose an automatic weld on mesh objects could be useful. I imagine that until such an option exists you could create a macro that does the import and weld automatically.
any solution for this
I think you might want to explicitly state the problem and provide a file that shows the issue.
i have the same issue with every fbx file that i export and import for example blender or c4d
Same issue. I’ve exported OBJ and FBX from blender. Each time, they come in as unwelded surfaces in Rhino.
