Fatal error after Visual Arq in RhinoInsideRevit
Hello everyone, after I opened Visualarq in rhino inside revit I am getting a fatal error after loading VA (3.1.1) in rhino 8. I can even load the VA plugin, but whenever I click on the layer pannel, or pushnpull command and some others, it gives me fatal error.
Really need help in this.
Error Details
Object: Gh_param_ListTextOptions (level 1)
Exception has been thrown by the target of an invocation.
TargetInvocationException
Object: Gh_param_ListTextOptions (level 2)
The type initializer for ‘’ threw an exception.
TypeInitializationException
Object: Gh_param_ListTextOptions (level 3)
The type initializer for ‘A.cab3adf7976f072e569f2d20ea1b40b84’ threw an exception.
Object: Gh_param_ListTextOptions (level 4)
Could not load file or assembly ‘RhinoNestKernel&, Culture=neutral, PublicKeyToken=null’. Foi feita uma tentativa de se carregar um programa com um formato incorreto.
BadImageFormatException
Object: Gh_param_ListTextOptions (level 5)
Bad IL format.
Object: gh_nesting (level 1)
Object: gh_nesting (level 2)
Object: gh_nesting (level 3)
Object: gh_nesting (level 4)
Object: gh_nesting (level 5)
Bad IL format.
Object: Gh_param_GlobalNestingCriterion (level 1)
Object: Gh_param_GlobalNestingCriterion (level 2)
Object: Gh_param_GlobalNestingCriterion (level 3)
Object: Gh_param_GlobalNestingCriterion (level 4)
Object: Gh_param_GlobalNestingCriterion (level 5)
Bad IL format.
Object: gh_RhinoNestObjecCreator (level 1)
Object: gh_RhinoNestObjecCreator (level 2)
Object: gh_RhinoNestObjecCreator (level 3)
Object: gh_RhinoNestObjecCreator (level 4)
Object: gh_RhinoNestObjecCreator (level 5)
Bad IL format.
Object: gh_param_ObjectOrientation (level 1)
Object: gh_param_ObjectOrientation (level 2)
Object: gh_param_ObjectOrientation (level 3)
Object: gh_param_ObjectOrientation (level 4)
Object: gh_param_ObjectOrientation (level 5)
Bad IL format.
Object: gh_param_ObjectCriterion (level 1)
Object: gh_param_ObjectCriterion (level 2)
Object: gh_param_ObjectCriterion (level 3)
Object: gh_param_ObjectCriterion (level 4)
Object: gh_param_ObjectCriterion (level 5)
Bad IL format.
Object: gh_param_nesting_parameters (level 1)
Object: gh_param_nesting_parameters (level 2)
Object: gh_param_nesting_parameters (level 3)
Object: gh_param_nesting_parameters (level 4)
Object: gh_param_nesting_parameters (level 5)
Bad IL format.
Object: gh_nesting_parameters (level 1)
Object: gh_nesting_parameters (level 2)
Object: gh_nesting_parameters (level 3)
Object: gh_nesting_parameters (level 4)
Object: gh_nesting_parameters (level 5)
Bad IL format.
Object: Gh_remap (level 1)
Object: Gh_remap (level 2)
Object: Gh_remap (level 3)
Object: Gh_remap (level 4)
Object: Gh_remap (level 5)
Bad IL format.
Hi Leo,
Please do not double post.
If you do need to post a large amount of text you can use the Hide Detail options here..
I “doubled it” because the other topic subject wasn’t this problem I am having.
Hi @Leo13,
I think this is related to a known issue in Rhino.Inside Revit.
Make sure you have Rhino.Inside Revit 1.26 or later.
Enric
it seems that normal grasshopper is trying to use rhinsiderevit grasshopper commands and they don’t exist.
I was using 1.27, I uninstalled it and still happening the same error over and over again
Hi @Japhy , Enric is saying that the problem might be with rhinoinside, can you help me? I am lost in this situation and need to get back to normal rhino situation.
Certainly,
Please provide your Rhino.Inside.Revit system about info.
Next step in troubleshooting is to temporarily remove Revit Addins
The next step after that is to disable 3rd party plugins from Rhino (including VisualArq)
We may need to look at 3rd party GH plugins as well. Let me know if the above doesn’t isolate the issue and we can next step.
I unninstalled revit, thinking the problem might be it…I tried loading grasshopperonebyone and if I run it without any plugins its ok, even can use VA … but how can I know what plugin is giving me this problem??
Ok, found where the problem wass caming from, and it was rhinonest
Hi @Leo13,
Great!
Please let us know if you encounter any compatibility issues between VisualARQ and Rhino.Inside.Revit 1.27.
Enric
Hello Enric,
Im facing a similar issue, and unable to diagnose this issue. i have updated my visualarq, rhino and rhiniooinside. i initially thought the problem was with my VA model, but i cannot create a new visualarq element in a blank file either. All this is only in Rhinoinside with Rhino and VA loaded up .
Hi @Aditya_Bhatt there was an error in the RiR plug-in that affected VisualARQ to run inside Revit. This issue has been fixed in the upcoming Rhino 8 SR27
