Facade optimization with regular panels
clear
1.066 / 5.000
Risultati della traduzione
Risultato di traduzione
hello everyone, i should create a grasshopper algorithm to tessellate a surface of a building (i’m talking about the Heydar Aliyev Center in Baku). I created the surface and inserted it into the ‘geometry’ component. once the tessellation is done (either with rectangular panels or other shapes), i should create an algorithm that allows to minimize the number of panels of different shapes. each panel would be different in area and curvature. Could someone give me some points?
This post six days ago in another thread has gold colored groups to get minimal sets of unique faces to build a facade:
hello everyone, I need a favor I’m desperate.
I should create a grasshopper algorithm to tessellate a surface of a building (i’m talking about the Heydar Aliyev Center in Baku). I created the surface and inserted it into the ‘geometry’ component in GH. once the tessellation is done (either with exagonal panels or other shapes), i should create an algorithm that allows to minimize the number of panels of different shapes. each panel would be different in area and curvature. or, instead of differentiating based on area and curvature, differentiate them based on different shapes, all of which have a flat surface. In short, I need to create an algorithm that optimizes my facade. Could someone give me some points?
I share rhino and gh files, in the rhino file you can find the building (on the right there is its surface connected to the geometry component of GH).
I am infinitely grateful to anyone who can help me
Heydar Aliyev Center GH.gh (10.8 KB)
Heydar Aliyev Center.3dm (18.5 MB)
hi Joseph,
thank you very much for replying me. Could you explain me how do the gold components worked?
Im new in GH.
