Extrude normal to surface error
Attached are two surfaces that have been exploded from a polysurface.
I tried to simple extrude a curve normal to the surface, using “_fin”. However, it seems to go into some form of hissy fit, and I cannot see why. Perhaps I created the surfaces incorrectly?
It’s like it retains history of being attached to the other surface. Even deleting the other surface reproduces the same error.
EDIT: I do note that in my case, I can explode the resulting fin polysurface, and get rid of the nonsense, and return what I think I should get.
Rhino_CrvNormExtr.3dm (158.4 KB)
Hi David - I see that - it does what I think you want if you DupEdge and Fin that rather than the edge curve directly. I’ll add this to the bug pile, thanks for the report.
RH-76377 Fin: Too much fin
That’s amusing.
I have always been using DupBorder and then deleting what I don’t want. Worse, I have been always use CopySubCurve as an alternative and selecting the whole edge. I have never realised there is a DupEdge.
Hahaha!
Thanks.
David.
