Extrude issues
never had an issue and all the sudden last week when I try to extrude its no longer a solid but says its a solid. I have made sure it is joined into a closed curve but it still isnt working properally. Does anyone know a fix for this?
If an extrusion won’t cap, it’s either not closed or it’s not planar. If you know it’s closed (look in properties or SelClosedCrv), then it must not be planar. Post the curve here if you like, someone will look.
–Mitch
