Hi to all,
the problem that I describe below has already been discussed in another post, but unfortunately I have not found solutions on this. The problem lies in the extremely slow VA in viewport.
I state that before writing the post I have already tried with the following options:
disable third-party plug-ins;
disable grasshopper;
try with different series of nVidia drivers;
try with earlier versions of VA than 2.11.3.
Each attempt described has not brought benefits, with VA the viewport is so slow as to stall Rhino (I’m talking about trivial operations such as the creation of walls or the insertion of windows or doors).
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 9-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.12
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-13-2021
Driver Version: 30.0.14.7212
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
Thanks in advance for any other tips on this…if they exist at the moment.
This post is previous to the release of VisualARQ 2.11. In that version speed was improved, so those problems should be solved.
I have been testing your file with VisualARQ 2.11.3 and it worked fine to me:
Does the slow performance happens if you disable VisualARQ as well? You will not be able to create walls, windows or doors, but maybe you can reproduce it with other Rhino commands.
Did this always happened or did it start after any change in Rhino?
@alfmelbev
Hi Alfonso,
i know that that post was referring to a previous version, but the video posted by the user of the post is identical to what happens to me with the current version of VA. The problem of slowness is not inherent in the speed of movement of the geometry once created, but precisely in the creation of the geometry. In other words when I try to create walls, insert windows, etc etc, VA is very very slow. Rhino has no slowdowns of any kind, only when I work with VA does the problem show up.
The really strange thing is that with the previous video card these problems did not exist. At this point I believe there is some sort of incompatibility with my current RTX A4000 and VA, as it is the only recent change to my system. On the secondary pc (where the old video card is installed) I have installed VA in demo and there are no problems. Personally I have done all the possible tests, but the problem still exists.
We don’t have previous reports of problems with video cards. If the problem is not about the display, it shouldn’t be related with the video card. Are you using an AMD Ryzen processor? If not, which one are you using? Did you make any updates in your PC before the problem started to happen? (Windows, Rhino…)
@alfmelbev
Hi Alfonso,
after trying everything (including reinstalling Rhino 7 and VA from scratch) I tried installing RH6 and VA for 6 as a last resort. Not surprisingly, VA for 6 is practically a bolt of lightning!
I trust that in the next updates the situation (obviously for me) will improve to be able to return to the “classic” combination.
Soon,
Ok, thank you for the update. If it is working fine with Rhino 6, then it must be a problem involving Rhino 7 or VisualARQ for Rhino 7. We will keep this in our list in order to find a solution. If you find out any more relevant data about this issue, please, let us know.
