Looking for a way to extract multiple evenly placed U Isocurves from a surface in grasshopper.
This will divide the surface equally in uv parameter space, not equally in xyz world space. It’s not entirely clear which of the two @dmweekes1 is after, but I suspect the second.
Same problem with @Baris’s solution btw.
To divide equally in xyz space (in sofar as that is possible at all with a curved surface) one would have to divide one of the edges into equal length segments, then project those division points back onto uv space and only then generate the iso-curves.
Thanks David, how would you project onto uv space?
- nevermind - i just used surface closest point to translate! Thanks
PT- Paneling Tools plugin.
Remaining 2 components: WombatGH plugin
@Robinicks Grasshopper Docs website will help you next time:
Cheers,
BVR
BVR : BUSTED ![]()
This is ISOTRIM?
I dont think so. Looks like some kind of domain component. I wish replies were held to the same standards as questions. I wasted an hour looking for this…
I want a range of isocurves.
So you’re looking for Range:
Next time you can use this VB Script from @DavidRutten which produce an image of all your components with icon and name. Recently i got this from old thread (2012)
CreateIconMap.gh (4.1 KB)
eg:
Thank you, But I dont see any output
Did you look in your %documents% folder?
