hi,
currently I am facing a problem while shifting from rhino 7 to rhino 8, As I am using “Get Mesh Topology directionals” component in stripper plugin to extract curves in U and V directions
but unfortunately, stripper is not currently compatible with rhino 8
is there any way else to extract curves in U and V directions of a mesh ?
thank you for your response, it’s very helpful and this component is pretty close to what I want but it extracts the existing edges of mesh instead the component in stripper plugin extracts the topological flows of meshes in U, V directions. if there is any component close to this it will be great.
What do you mean by “topological flows” here? You want curves that aren’t made up of mesh edges? There’s also the ‘stripper’ component under the Kangaroo mesh tab which extracts strips of faces
I think, “topological flows” mean to capture topological changes along surface instead of actual edges, but wrapweft component is very useful, thanks for your help
