Hey guys, can someone tell me how to fix this…
The below image is a patch surface applied to an imported .dxf file, the yellow outline indicating the .dxf. From here I need to trim the holes but once I select the trim command I have those additional black lines appear. You can see on the central hole is only partially trimmed because the black lines are acting like trim boundaries.
How do I get rid of this?
