When I import a dwg into rhino it comes in with extra geometry that is part of certain objects. This geometry is not there in the dwg. This dwg was originally a revit model exported as a dwg which I then imported into rhino. Any thoughts? See images
Hello - it may be that there are planes in the revit model that are reference planes and these come in as planar surfaces in Rhino, or, possibly, some planar surfaces are coming in un-trimmed.
thank you @pascal. I think it’s untrimmed planar surfaces. Is there a way to fix this so I don’t have to explode, delete, and remake the right surfaces?
Hi Jun - are the surfaces ‘free floating’ or attached to something else … I’m not picturing what you have there - can you post an example or send to tech@mcneel.com?
