ExtendCrvOnSrf indication
It would be handy if there was a quick way of seeing what ends are extended with this command. A lot of the time I’m using it it’s in situations where I didn’t think I would need it and need to know which adjacent surface isn’t quite extended as far as it’s supposed to be.
If you have an example or two of where this would be helpful, that would certainly help to ensure we make the right improvements. Are you able to share an image, video, or maybe a model that shows the situation where you may need this?
If so, we can try to get this added to the wish list!
i would love to see:
direction indicator (like Dir command)
(would be enough to see start / end)
dot-like (maybe transparent) info:
  • 1,2 for start End - or 0,1 (Numbers are nicer in terms of language specific S
  • Color
    • one color for beyond the surface edge (i love blue = in the air)
    • curves starts / ends on surface edge ( green = ok, nothing to do here)
    • curve is inside surface (red = bad = action for the command needed)
what is not obvious - and i would claim it is a error-trap:
A “Start / Endpoint on Surface”-Curve is also treated as “Curve on Surface”.
This curve just has its Startpoint on the Surface:
and is extended with a “kinked” Line-segment
i can not imagine any modelling workflow where this makes sense.
so maybe it s a more complex UI-Refinement:
ExtendCrvOnSrf should not only give a start / end indicator but also provide more info before the command runs
is the curve on the surface (within doc tolerance)
are the ends on the surface
Direction / Start / End
after the execusion / or if the command failed - more then just the info “one end was not ont the surface”…->
was the extension smooth or just a kinky line segment
happy to give feedback on any prototype … or UI-mock-up
kind regards - tom
crvOnSrf.3dm (3.0 MB)
