Extend off variable fillet surfaces
It would be a great time saver if the extend could be turned off in the variable fillet surface function. Need to split them manually, in the normal surface fillet one has a choice to turn it on or off, like the trim and join.
Eric
Or to have the rail options in the surface fillet like in solid fillet edge/variable fillet surface.
While at this, RMB does not always repeat the variable fillet surface command. Some kind of random behaviour, cannot yet reproduce a pattern.
Hi Eric- thanks, I’ll see if these can be added.
Thanks!
