I am trying to export my floorplan lines from rhino into illustrator to annotate and poche the plans. When I am exporting from Rhino to Illustrator my floorplan lines get super messy. Some of the lines get deleted and some of the curves change shape. It is very strange. I have tried just about every type of exporting option. I got it to work once when the lines weren’t super messed up but I wasn’t able to use the live paint command in illustrator. I have also tried to make my drawing 2D in rhino and that messed up the file. I have attached a copy of my rhino file and some pictures of things that happen when I export.
Well, in this case, you should give a try to rhino 6 (at least to see the difference): the illustrator output has been improved and you won’t get “potatoïd” shapes anymore.
