Exporting files for use in Arc GIS Pro
I’ve been struggling for some time to export various elements from my Rhino Models to be imported into Arc GIS pro.
I get data from many different sources and often have no idea what program generated the files but they usually come as dxf files and I use Rhino 7 to assemble everything together, add fairly simple elements to the model and then look to export those elements in order to add them to a Arc GIS 3D scene. Most of my original data imports into Arc as expected but the files I create in Rhino often come in georeferenced differently or the file shows but is empty. In the past I have had success importing into Google earth using earth anchor and then exporting to kmz but this doesn’t seem to work in Arc. It seems like rhino Understands the georeferencing of my original data when I import it but when I export to the same type of file it loses it’s referencing.
If anyone has any ideas I’d love to hear them.
Thanks,
Russell
Hi @nofussrussell ,
Are you able to import into ArcGIS, but the data just comes in at the wrong place? I don’t use ArcGIS, but in QGIS, you can set the coordinate reference system (CRS) of an imported layer in it’s properties after you import. I’m guessing your exports from Rhino have no CRS set.
To help with more detail, please post some example files that illustrate your issue.
-Brian
Hi @nofussrussell
I realise this thread is more than three years old, but it caught my attention, so I thought I would add a few observations in case they are useful to anyone who comes across the same issue.
I previously worked with CAD data in ArcGIS Pro, and I think Brian’s point about the coordinate reference system (CRS) is important here.
I would probably separate the issue into two parts: the spatial reference of the CAD data, and the compatibility of the 3D geometry itself.
First, I would check what happens to the coordinate values when the data is imported into Rhino.
If the original CAD data uses coordinates from a known projected coordinate system, and those coordinate values are preserved in Rhino, then the geometry may still be correctly positioned numerically. In that case, ArcGIS Pro mainly needs to know which CRS those coordinates belong to.
On the other hand, if the geometry has been moved close to Rhino’s origin and the relationship to the original real-world coordinates has been lost, then the original location cannot be determined from the geometry alone.
So, if possible, I think it is important to identify the coordinate system of the original CAD data first.
I also noticed your comment that sometimes the file appears in ArcGIS Pro but contains no visible geometry. I encountered something similar in the past when importing 3D geometry from Rhino into ArcGIS Pro. In my tests, Rhino NURBS geometry did not import reliably, whereas converting the geometry to a mesh in Rhino before exporting allowed it to be imported successfully.
I cannot say that this is necessarily the cause in your particular case, but if the file is recognised by ArcGIS Pro while the 3D geometry itself does not appear, I would also test a meshed version of the same geometry. This may be a geometry-compatibility issue rather than a spatial-reference issue.
For the spatial reference, I would consider two possible workflows:
  • In Rhino, use Heron to establish the relationship between the Rhino model coordinates and real-world coordinates, then make sure that the appropriate CRS is assigned when the data is brought into ArcGIS Pro.
  • Alternatively, bring the CAD data into ArcGIS Pro and georeference it there. A PRJ file can define the coordinate system, while a WLD/WLD3 file can be used when the CAD coordinates also need to be translated, rotated or scaled into the correct real-world location.
In short, I would try to distinguish between three possible issues:
  1. whether the coordinate values themselves have changed in Rhino;
  2. whether the coordinate values are preserved but the CRS is no longer being recognised by ArcGIS Pro; and
  3. whether the coordinates and spatial reference are correct, but the Rhino 3D geometry is not being interpreted correctly by ArcGIS Pro.
For the third case, converting the Rhino geometry to a mesh would be one thing worth testing.
I hope this is useful, even several years later.
Kensuke Nakata
