Exporting animation from a slicer component in grasshopper
Hi everyone! If anyone is familiar with animating geometries in grasshopper and/or rhino i would appreciate some help. I need to do an animated .gif of the section plane in the file below. In the animation, the slicer in the grasshopper file will cut through the mesh in a certain speed, and at the same time the section curves will appear above the mesh like in the screenshot below. I put a timer in the slicer and it looks fine on screen but how i can export that in a file?
Thanks in advance for your replies!
https://we.tl/t-EDxIvXG4Vl
Why use wetransfer.com instead of just posting your file here?
Welcome to
  • Simple file-sharing
  • No registration
  • It’s free
To continue, please agree to our Terms of Service.
OH!!! 35+ MBytes??? “Failed - Network error” - WAY TOO BIG
The usual procedure is to drive the animation with a slider, then right-click that slider and click “Animate…”.
i saw that in other threads but i cant figure out how to use a slider in my case…because the component needs a timer not a slider
Change that!
To get help with your code you’ll have to isolate a smaller version of the geometry/file so we can see it.
Here’s a simple example to play with:
animate_2020Dec14a.gh (12.4 KB)
P.S.
animate_2020Dec14bb
animate_2020Dec14b.gh (14.8 KB)
thank you so much!
