Export to OBJ
These are the settings I used:
Also I’m not sure how much of a difference it makes but I’m using 3DS Max 2020, latest version.
Hope that helps!
Yes it helps and we’re getting closer. Import as a single mesh was not boxed at my import. When I do i get the same smooth import. However… I need the multiple layers. So when I export all the layers in Rhino I need them layered in max as well. So I export materials and then I only need to materialize each layer in stead of every single object. So when I import as single mesh I do not get the layers.
I’m not maried to OBJ. But this works great in Rhino 3 and 4. In Rhino 6 I get this problem.
If there is another format where I can export layers in one go and get the layers with the same layer name in max (as one object would be best) I would be extremely happy.
Hello there.
I believe you are suffering from the same thing as I am, which I have posted about here.
It appears to me that the exporter has been changed and creates files that max now hates.
