Export single closed mesh
Export a SINGLE closed mesh (joined and/or welded meshes) with “Shapediver Download Export” as an STL results in UNjoined MULTIPLE meshes in that STL-File.
The export process work in the background like the command: SplitDisjointMesh !!!
I’d like to turn that background process off, or …
How could I change export settings/options for “shapediver Download Export”? More than binary!
The SINGLE closed mesh has NO naked edges AND NO non-manifold-edges (_ShowEdges) !!!
Rhino details talks about a “VALID mesh”
Rhino check talks more infos about my mesh.
rhino_check.txt (1.0 KB)
Could you attach a minimal example definition and the resulting mesh you are getting after export so we can try to reproduce the issue? I just tried on a simple example and it worked as expected.
Same failure with (Rhino Export Selected) and (Grasshopper Shapediver Download Export Export Locally)
example_shapediver_support_forum_rhino_check.txt (1.1 KB)
example_shapediver_support_forum.stl (211.7 KB)
If I understand correctly, you are getting the same results by exporting directly your files in Rhino and using the ShapeDiver Export component. In that case, please post your question in the general Rhino forum so you can get help from there.
