Hello
I just moved up from Rhino V5 to V7 and noticing that multiple objects exported as an .stl, becomes a single selectable item when I open the .stl file.
If I wanted to delete or reposition a portion of it I have to explode it.
Is there an option to keep them separate during the export?
Thanks in advance
Murat
Make sure this is checked on import:
The box should be checked, not unchecked. You can also run the command SplitDisjointMeshes in Rhino after the fact. (I love phone automatic corrections)
That worked. Thank you.
Hello- if you get it wrong, SplitDisjointMeshes will sort it out.
