Export selection to PDF colour / contrast issue
Hello. I’m having problems exporting to PDF format in Rhino 7. The colors and contrasts are completely different than in the rendered top view. The view also contains image files as surfaces. Everything in the PDF is so bright and pale. I’ve already tried deactivating everything in the light and weather settings, but to no avail. Then I’ve already tried: Display > Save Viewport to File - but the line thicknesses of the curves are not taken into account there. Does anyone have an idea how I can solve the problem?
Best regards.
Can you post a 3dm file that shows the problem?
It’s done. I separate the lines and export them as a PDF. Then I use Display > Save Viewport to File to save the plan view without curves as an image file. Then I use an image editing program to copy the lines, which I previously converted as an image file, to the plan image file and scale it. I use the magic wand to delete the white background from the image file of the lines. It’s a bit cumbersome, but it ultimately preserves the colors and contrasts. I don’t know how to help myself any other way. But it works.
