does the export rhino to dwg keep original coordinates ? Seems that when I reimport in sketchUP the coordinates are set to the origin, I tried also export with origin but same result
Hello - as far as I know the coordinates should be as in Rhino. You may want to check ModelBasePoint in Rhino.
seems they got exported to 0,0,0 which is handy, but not what I would like to do now, ok , I ll check model base point
