Hello Dear Rhino Community,
I’m facing a challenge with about 80 DXF files from a graphic designer. In each file (DXF), when opened in Rhino, there are multiple layers. However, I am only interested in one specific layer, which I need to export again as a DXF (it’s used to cut an outer diameter from plywood).
Is there a workaround so I don’t have to manually open each file, select the curve, and export it?
Thanks for reading, and best regards in advance.
Leo
