i have a lot of problems exporting obj and fbx look at the screenshots first i will show you mine
obj export settings and the results after importin in artlantis
Hi Peter,
Did you build this in Rhino? If so have you checked which way your object’s normals are pointing. It looks like a classic case of normals flipped the wrong way. In Rhino try using the flip command and select the problem surface or model part. I have a view mode which is called back faced which shows flipped surfaces in a color so I know before export if the normals are flipped the wrong way. Don’t know if that’s the problem for sure but I attached my view back face ini file might help. BackFaceRendered.ini (12.0 KB)
RM
Thanks this make sense i had e=a screen shot back from a (client) they say the same wrong normals
but how can i know what is the right direction of the normals ??
greetings Peter
by the way your file is an ini file i really don,t know what i can do with it i can open it in a text editor
Use the provided ini file, it’s a view mode that shows in Red the direction the normals are pointing. Go into options, viewmodes and import the ini file, then use that as a view mode by right clicking on any viewport title and selecting the Backface view mode. If your surface or shape is red it most likely has normals pointing in the wrong direction, select the surface and type: flip in the command line and the red color should go away meaning the surface is now most likely pointing in the correct manner.
You can also use flip command without the provided view mode but Rhino won’t show any difference to the eye but will report at the command line: flipped normals of one object.
thanks you make my day problem solved- i only don understand this issue maybe someone can tell me somthing more about it …but anyway i can carry on-
thanks 3dsynergy !!!
