Hi there,
I have not found anything in RhinoCommon about exporting items.
So far I use the command line, but it is a bit bulky (like the import as well).
Is there an option in RhinoCommon to export items (to 3dm, step, dxf, …)?
I could easily be overlooking this, I’m still fairly new to scripting, but I didn’t see a way to set the export options when using the RhinoDoc.Export or RhinoDoc.ExportSelected. Mostly looking for options like save textures when exporting to fbx or choosing the export scheme when exporting to dwg.
@David_Moreau, this only works from Rhino7 on, right.
One thing that would make this method perfect is to be able to chose export settings (for dxf or step for instance), @stevebaer. (Only in case I did not miss them… )
I’m happy that you guys are pointing out that the options is what is missing. I do know that and need to figure out a decent approach for dealing with adding options.
@stevebaer, I might be disimproving this, but…
Are you planning to create a method that does not require to select objects?
Wouldn’t it be more convenient to simply pass a list of geometry and attributes into the method.
import Rhino
doc = Rhino.RhinoDoc.ActiveDoc
doc.Import( r'path') #you can also define import options as ArchivableDictionary class
doc.Export( r'path' , options)
