Export to STEP
I’m trying to export to STEP in RhinoCommon. I can only find this class which is only available in Rhino 7 Windows: https://developer.rhino3d.com/wip/api/RhinoCommon/html/T_Rhino_FileIO_FileStp.htm
What’s the recommended way of doing it in Rhino 6, or on Mac?
Thanks!
Best,
Aske
Hi @aske,
Just script the Export command using RhinoApp.RunScript. Here is an example of exporting to DXF. This should give you an idea how to do the same with STEP.
SampleCsExportDXF.cs
– Dale
Hey @dale,
Thanks for the reply!
I want to do something like this:
var doc = Rhino.RhinoDoc.Create(null);
var tmpObj = doc.Objects.Add(myGeo);
// TODO: Manipulate tmpObj in the new document, without altering it in the original user document. E.g. reorient it.
// TODO: How do I choose which doc RunScript targets?
var script = $"_-Export \"{filePath}\" _Enter";
RhinoApp.RunScript(script, false);
Maybe this is a convoluted way of thinking about it? Should I instead make a copy of the geo in the current doc, manipulate that, then select it (I find programmatic selection a bit awkward/hard), and then run export selected?
Or is there a third, better option?
Thanks!
Hi @aske,
For Rhino 6, you’ll need to add your objects to the existing document and then script the Export command.
– Dale
Alright.
Thanks for the quick responses!
