Hi everyone.
Is there any way to export a dashed line from Rhino in PDF format as a single curve?
at the moment the dashes and points are divided into single segments.
Thanks
I don’t know if it works, but could you make them a single line, put them in a seperate layer, export and then edit them to dashed using adobe illustrator or some other program?
I wanted to have continuous curves to modify them in illustrator, and it works, thanks!
However the texts sometimes are exploded letter by letter. Do you have a solution also for this?
