In Rhino 5.5.5, when I print to (save as) PDF to generate layouts, my dashed lines are all converted to continuous lines. Does anyone know why this is happening?
Many thanks.
Many thanks.
Hello - as far as I can see that is not the case here - make sure in the Print dialog > Linetypes and Line widths that the linetype scale matches the pattern definition or viewport display, as appropriate.
Feel fee to post an example rhino file.
Hi Pascal,
As usual, you have nailed it!
I did not have the “Linetypes and Line widths” set to “Match viewport display”; the dashes are lost when the default “Match pattern definition” is used.
Many thanks,
John
