Explodable 3D Text - Similar to Fabtools 3D Text Advanced
@LyndonJ, same problem here, actually even worse, some of my text goes upside down when I explode the text inside rhino.
Our problem would be solved with a curve output, right?
@DavidRutten, what do I need to do not to have my numbers upside down? Command bar says Curves from text may orient differently than text in viewports because of Annotation style settings. There is an option inside Annotation style settings but for me, it doesn’t do anything. On the screenshot you can see text on overhanging surfaces of a climbing wall. I want the text aligned the way I define inside Grasshopper.
Plus can we please get a curve output on the 3D Text Tag?
Thanks for your help!
Yes, we can bake text and extrude it to solids. But isn’t the whole point of Grasshopper that we can actually automate everything? That much for the person who’s telling me I need to bake the text in order to select it, extrude in 20 different directions and subtract from another few solids to get my text engraved… :sob:
