Exoskeleton Nodes Creating Bad Meshes
I have been working to understand the cause of a few of the Exoskeleton nodes generating strange mesh faces. As currently configured, most of the nodes in my model are turning out as desired, so I would appreciate some help understanding the mistake I’m making that’s producing this bad geometry. Please see attached images.
I’ve also run into that issue and have fixed it with a varying level of success by using different values for the sides and mesh density. Sometimes it just seems to not work…
You might want to consider Dendro https://www.food4rhino.com/app/dendro. It doesn’t have the cleanest mesh arrangement but the algorithm is very sturdy.
Fair enough, thank you for your help! I will definitely check out Dendro.
