nowak993
(Nowak993)
January 3, 2019, 1:19pm
1
I’m just learning a grasshopper and I need your help.
I would like to change an irregular shape into an exoskeleton.
I did it but I need to make changes. See the pictures below, curves marked in green was baked.
I need to add some curves and delete some curves, curves like in pictures below.
But when, I set baked multicurves after these changes, I have error on Exo plug.
the difference is the type of line so I think
Do you have any idea how to deal with this problem?
Best Regards
Exoskeleton was a good solution, but you could replace it with Dendro which is more robust.
nowak993
(Nowak993)
January 3, 2019, 6:49pm
3
Laurent,
Thanks for Dendro, but I have the same problem like in Exosceleton.
Look
Screen capture are good for greetings not for curing problems. BUT
Dendro doesn’t like null things, so use that to sort curves and null
And read this
Asking questions and getting answers is what this forum is all about. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions, but don’t think of them as rules and especially don’t think of them as guarantees.
1. Choose a descriptive title for your post
Don’t title your question Help! or I have a problem or Deadline tonight!, but actually describe the problem you are having.
2. Be s…
