Existing Rhino Functionality to Rebuild Unstructured Quad Layouts from Polyline Surface Boundary Data
Hi Pascal,
Thanks for the response. I’ll use another image to describe the problem:
Say I want to rebuild this trimmed annulus with the minimal number of surface spline patches supporting this configuration of extraordinary points. The rebuilt Brep will contain 6 surface patches and will look as above. I can use the following commands for the following labeled surfaces:
  1. Brep.CreateEdgeSurface
  2. Brep.CreateFromSweep
  3. I cannot find an existing command that works – I have a closed loop closer to the center of the annulus and an open curve closer to the exterior.
Thus, each surface is well-defined except the surface labeled 3, where I cannot find a command that will yield the surface in the white space. As a result, I cannot seem to convert this trimmed surface into an untrimmed Brep.
I have looked at ways to open a closed curve (for the purpose of sweeping, for example), but this discussion seems to signal that this is impossible in Rhino.
Do you have any recommendations on how to generate the surface labeled 3?
Thank you, as always, for your help.
