Exclude clipping planes from Make2D?
I’ve noticed that clipping planes (widgets) occlude objects behind them in Make2D. I think they should be invisible? I think that you’d rather use an actual geometry to hide objects rather than a clipping plane.
Spotted when one clipping plane came from a linked block.
Yes, I see this, thanks for reporting. RH-72031 Clipping planes in 3dm files inserted as linked blocks, will be treated as normal planes
Brilliant, thank you :tada:
RH-72031 is fixed in Rhino 8 Service Release 18 Release Candidate
