EvolveLAB Veras for Rhino 7
Veras is an AI-powered visualization add-in, that uses your 3d model geometry as a substrate for creativity and inspiration.
We have released a new version of Veras (0.9.2.0) that includes support for Rhino 7 (Windows)! Feel free to check it out!
Examples
To see more Veras examples, you can check out the Veras Gallery on our forum:
dale
(Dale Fugier)
April 25, 2023, 7:18pm
3
Hi @benjaminguler ,
You might consider adding a landing page on Food4Rhino, as a lot of Rhino users look for tools here.
– Dale
@dale - Thank you for the suggestion! I started the process, and we should have it up there soon.
We also have a new Veras for Rhino video that includes some neat workflows, some using grasshopper.
Main topics covered:
Using Veras for AI visualization in Rhino
Using Grasshopper3D and Rhino3D combined with Veras to create AI Generated Designs
Using ChatGPT and Prompt Engineering for Veras paired with Rhino3D and Grasshopper3D to explore design Ideation .
V1 Veras Release
Veras v1.0 is now officially released, featuring higher geometry retention with the new Geometry Override slider.
Release Notes: Veras - Release 1.0.0.0 - Veras - EvolveLAB Forum
Examples
V1.2 Veras Release
Veras v1.2 is now officially released, featuring Render Selection , 2k Resolutions , a revamped UI, and many more improvements.
Release Notes: Veras - Release 1.2 - Veras - EvolveLAB Forum
Examples
Render Selection
Higher Resolutions & Render Engine V4
V1.3 & 1.4 Veras Releases
Veras v1.3 & 1.4 brings some sweet new upgrades: V5 Render Engine with superior quality and resolution improvements, Explore Mode , 4x render speed with Simultaneous Renderings , and many more improvements.
Release Notes: Veras - Release 1.3 - Veras - EvolveLAB Forum
We will also be releasing support for Rhino 8 soon!
Render Engine V5
reference:
Ricardo Maturana | LinkedIn
reference:
rmaturana | Instagram
Explore Mode
V1.7 Veras Release
Rhino 8 is now fully supported!
no need to use this workaround anymore: Rhino 8 Veras Workaround - Veras Rhino - EvolveLAB Forum
Features
New Enhance Render feature available under the EDIT tab
SSO Login - users can now sign in using Single Sign On!
16:9 default resolution for the Veras plugins.
Render Selection from base image
the render selection uses the base image for structure instead of the rendered image
Release Notes: Veras - Release 1.7 - Veras - EvolveLAB Forum
Enhance Render
Enhance Render with Render Selection
V1.8 Veras Release
Release Notes: Veras - Release 1.8 - Veras - EvolveLAB Forum
Food4Rhino: Veras® | Food4Rhino
Features
Zoom / Pan Images
Interactive render selection blend
Undo last point when drawing the render selection shape
Save button on thumbnails
Updated icons and icon enabled state appearance
Stability
Fixed the “Invalid Signature” issue when installing Veras for SketchUp in Windows
Clearing the render selection mask would not clear after pressing circle X button
Better icons support for browsers using different languages
Fixed bug where the original image could not be displayed for renderings generates using the RENDER SELECTION feature
V1.9 Veras Release
Release Notes: Veras - Release 1.9 - Presets! - Veras - EvolveLAB Forum
Features
Custom Presets! - you can now save your favorite settings to Veras for later use
New EvolveLAB Presets
21 new refined presets
all previous presets were updated to better work with the latest render engines
Refresh Presets button
Render Engine 6 Sharp - this increases the geometry retention drastically! Try it out!!
New Styles: Cinematic & Film Photography
turn these features on to change the mood and aesthetic of the generated render
Negative prompts - you can tell the generative AI what NOT to include in a scene
Updated the UI organization to flow better with the new features
Floating Licenses
Stability
Fixed a bug where the base image from the base app was not used as structure when rendering with lower geometry overrides
Fixed Upscale Menu bug where the resolution was not properly represented
Fixed licensing getting stuck when logging in
Fixed SSO issue with licensing for SketchUp
New Presets
Cinematic Style
Film Photography Style
V2.0 Veras Release
Release Notes: Veras - Release 2.0 - 3D Mode! - Veras - EvolveLAB Forum
3d Mode
The new 3d mode allows for a higher geometry retention. It also enables some really cool workflows
Select By Material
Resort Presets
Resort Renders
Favorite Renders
Draw Multiple Shapes
Recent Mask History
+ More
Features
3d Mode
Zoom to extents
Sync camera to parent app
Live sync camera
SketchUp, Revit, Rhino and Web app are supported
Web app supports OBJ uploads & Axis Alignment
Updated 2d/3d toggle UI
Render Selection Improvements
Undo freehand mask lines
Ability to draw all the way to the edge of the canvas
Select and deselect polygons & delete selected paths
Invert Render Selection
Added user email to the trial expired page
Preserve Thumbnail Width when Dragging
Auto-update app for non major releases
Hide “My Presets” if there are none
Disable the “scale render” when the scale factor is 1 (no scaling)
Stability
Bug Fix: ‘Cannot Parse Settings’ error the first time a user logs in
Bug Fix: Render Selection Mask Cropped for Renderings over 2048 pixels
Bug Fix: On auto re-login the ‘Login Form’ would briefly appear
Bug Fix: Arrow Keys Scroll Thumbnails Correctly in ‘Favorites’ Mode
Bug Fix: Handle empty models
Security
Known Issues
3d mode large model support is accessible from the Loader 2 setting, and currently has some geometry artefacts
SketchUp - if front-face material is default and only back-face has a material, the back-face material does not load in the 3d viewer
Need to add a Field Of View setting in the 3d viewer
3d render selection cannot select unpainted materials
3d render selection cannot select the background
loading a previous mask when changing the window size has alignment issues
Experimental Features
These features are subject to change, but feel free to try them:
Sketching Tools
Interrogate Image
HUGE Announcement: Chaos Acquires EvolveLAB
EvolveLAB JOINS CHAOS TEAM We are thrilled to announce that EvolveLAB has joined Chaos, a global leader in visualization and design technology. This milestone marks an exciting new chapter for our team, our customers, and the AEC industry as a...
