Hi!
Here is a thing I don´t understand:
As you can see, I have two attempts to evaluate a surface:
- In the first one, the gizmo appears outside the surface, so I have to use a “Surface Closest point” component to get a result.
- In the second one the gizmo is inside as needed. But i have to rebuilt the curves. This results in an inaccurate surface.
The question is: How can I get the evaluation in an accurate surface without using the “Surface Closest point” component?
Thank you
evaluate surface.gh (11.5 KB)
