Hello guys, someone know how to edit action of close button of eto frame ?
Please supply some code or example. It’s very hard to help without code.
, there is a picture , i just want to know if it s possible to edit this action , i don t have a source code yet.
You need to bound a method to .Closing event of your form, here is a small example that can print a custom text in the command window on closing.
import Rhino
import Eto.Drawing as drawing
import Eto.Forms as forms
class SimpleEtoDialog(forms.Dialog):
def __init__(self):
self.Title = "Sample Eto Dialog"
self.ClientSize = drawing.Size(200, 200)
self.Padding = drawing.Padding(5)
self.Resizable = False
self.Closing += self.OnFormClosed
def OnFormClosed(self, sender, e):
Rhino.RhinoApp.WriteLine("You can do whatever you want here")
#self.Close(False) you can even prevent the form from closing
def TestSampleEtoDialog():
dialog = SimpleEtoDialog()
dialog.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
if __name__ == "__main__":
Closing.py (705 Bytes)
If you want to know more about Eto forms in Rhino.Python here is a good point to start:
