I’m uploading some custom hatches and getting this error that they’re not supported. Any way around this?
Best,
Paul
Best,
Paul
@mary - any idea here?
Hi Paul -
I can’t tell if this is happening with specific *.pat files or generally with any *.pat file that you are trying. Can you post one that fails on your end?
Hi Wim!
I tested a few different files…All return the same message. I’ve created one using a makeHatch script, one is downloaded from a CAD website, and one from here on the forum. I do have the Custom Hatch Maker plugin installed and I may try uninstalling it and seeing if that makes a difference.
Hatches.zip (16.8 KB)
Best,
Paul
Also it looks like you can’t upload .pat files so let me know if there’s any trouble with that zipped folder!
Hi Paul -
No problems with the zip. I’ve added the *.pat extension to the list of eligible files here.
Those appear to work fine here in Rhino 7:
Please run the Rhino SystemInfo
and copy-paste the result here.
I just solved it by uninstalling the Custom Hatch Maker plugin
But here’s the system info in case it’s useful for anything
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Educational, build 2023-09-05
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.4575
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.4575
Driver Date: 7-11-2023
Driver Version: 31.0.101.4575
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
Hi @pdfaze,
You can import the .Pat file into Rhino.
However, there is no “drag and drop” support of .Pat’s, to what the the error is referring.
You need to go to Options → Hatches, and pick the Import button.
You can select all three .Pats.
And follow the prompts on the screen.
When they are imported, use the Hatch command to assign hatches to the close planar curves.
Let us know if this works for you.
Sincerely,
Mary Ann Fugier
That worked! Thank you
