I have a model using Karamba 3D plugin. In the analysis algorithm , it shows an error that says " 1. Model can not be calculated: there are no supports." while there is no error in support defined and it is correctly connected to the algorithm. Please advise how to solve this issue.
Hi, maybe your supports are defined in different data branches than your elements. Karamba3D follows the same data structure as in Grasshopper. Sharing screenshots or your definition would help us to understand your problem.
Hi, you do not need to plug the pts input into the AssembleModel, and it seems there are no supports defined. I see that the series has an input of 0 which will give you no numbers.
