Support Error
I optimised my slab through tOpos as form finding. Now, I wanted to perform the structural analysis on the optimised slab. However, the support issue is coming up. I have made supports at places where the column and the optimised slabs now intersect. Pls guide.
Final Slab.3dm (487.4 KB)
Model 1.gh (32.0 KB)
hello
the points on which you indicate supports are not part of your calculation mesh, which is defined in the “mesh to shell” linked to an “assembly model”.
For your information, Karamba does not make volume meshes, but only flat meshes.
Okay, thanks. Then for volume meshes, I should use Alpaca 4d?
You can also try to “extract” the axes of the slab as well as the thickness if you wish to analyse it in Karamba3D
