Error Opening Grasshopper
I am now getting an error when I start up Grasshopper. It tells me:
Priority: CategoryIcon
  Method not found: 'Serilog.LoggerConfiguration Serilog.FileLoggerConfigurationExtensions.File(Serilog.Configuration.LoggerSinkConfiguration, System.String, Serilog.Events.LogEventLevel, System.String, System.IFormatProvider, System.Nullable`1<Int64>, Serilog.Core.LoggingLevelSwitch, Boolean, Boolean, System.Nullable`1<System.TimeSpan>, Serilog.RollingInterval, Boolean, System.Nullable`1<Int32>, System.Text.Encoding, Serilog.Sinks.File.FileLifecycleHooks, System.Nullable`1<System.TimeSpan>)'.
  MissingMethodException
Environment:
  • Rhino v-8 SR17 (8.17.25063.13001, 2025-03-04)
  • Windows 11 Home v-21H2 | 22000.2538
Files:
all the best,
@ed.p.may
Hi Ed,
Can you try again but start Rhino 8 in Safe Mode? or troubleshoot by removing these 3rd party plugins?
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.54.16\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.54.16.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.257\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.257.0
Hi @Japhy, sure thing:
When i start in ‘Safe Mode’, I first see:
but Rhino does boot up. Then When I run ‘Grasshopper’ it says:
and then I still get the same error:
But, everything does appear to work as normal in Grasshopper once I close that error.
btw: note that I did just update Rhino, so now my environment is:
  • Rhino v-8 SR18 (8.18.25070.14001, 2025-03-11)
That is expected, you will prompted to load any plugin (grasshopper is a plugin), did you say no to the 3rd party plugins or remove them?
Also note that running windows on parallels is not a supported configuration. Rhino - System Requirements
oh - I just started in ‘Safe Mode’ ? I thought that would then not load any 3rd part items? I clicked ‘Yes’ load C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp?
yeah, I hear ya. FWIW, Everything was working awesome until SR17 and 18 though.
-e
Lets try a repair install. Go to Add & Remove Programs> Rhino 8> Modify>Repair
@Japhy nice! that did the trick :slight_smile:
I did a full Ladybug/Pollination removal, and ran the ‘Repair’ as you suggested, and now no more warning message when I open Grasshopper.
Then I reinstalled Ladybug via the Pollination installer, and now get the same warning message again. So must be an LB issue. I’ll post over there to followup.
thanks!!
@ed.p.may
