Just wondering what I should be doing regarding the following reference number?
Ref: b601a9bc-e9bd-411f-90e9-13fedcd2c188
Thanks,
Thanks,
Could you tell me what the error message was? It would also help if you could post a minimal version of your definition causing the error.
Oops! The server encountered an issue with your model:
Computation of your model failed. Please ask for help on the forum, including the reference shown below in your message.
(Ref: 7c0847f4-ccd4-4740-8586-1c92f014fc5a)
Your definition outputs a mesh with half a million vertices. You will need to reduce the size of your output or split it in several outputs with meshes smaller than 65536 vertices.
