I am putting a good use of Heron plugin, and importing geojson files as you suggested to my previous topic at the forum.
It works very well with most of my files, but when I try to read a single point, fields and values are readable but feature geometry is missing when using the importVector component.
Hi @amaraa,
Thanks for finding this bug! Currently the ImportVector component will attempt to read just the fields and values if the extents of the data is invalid or has a height and width of 0. As this is just a point, the extents have a height and width of 0. I will update the code for the next release to allow ImportVector to attempt to read the data if the extents are 0 and clipping is turned off.
For now, can you just use a vertex of the extents?
