Hello!
I would like view all Rhino commands, So i have run “CommandList”.
And i see this error :
Note i don’t have Faro machine but the plugin is active by default at the installation.
after click ok, the command continue and display the list.
Hello - yeah… the thing needs to load all the plug-ins to suck the command names I guess. I’m not sure if there’s a way around that error message, I’ll ask.
Meantime, this might help
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commandlist/command_list.htm
(Commands command)
Hello!
In my case I do not have Faro, so I disable the plugin.
That does not bother me.
this is to trace the behavior
thanks.
