Hi there. I’m using Rhino 5, on Windows. Never had a problem until tonight, but everytime I tried using Linear Array it said Uknown command. I’ve also googled to see if someone had a similar situation but it seems like it works differently for every command. Not sure how to fix this.
What if you try “ArrayLinear” instead?
// Rolf
Tried, it’s still the same. Also tried Transform toolbar-Array-Linear but didn’t work
Check PluginManager. I dunno what plug-in that command goes to but maybe you turned it off on accident? (I don’t mean third party plugins, I mean Rhino’s core)
@milabrstinic219
Here is what @Michael_Pryor is referencing:
- _Options or
- Rhino Options >Plugins
Make sure there is a check in Enabled
It seems like I don’t have Rhino Labs Tools as an option in PluginManager. Here’s what apperas in PluginManager:
Is there a way I can fix the problem differently?Hmm you should definitely have way more plugins. Maybe something went wrong or interrupted your Rhino install. Can you reinstall it?
Hm I see. Strange. Do you think that there might be some other way to fix the “unknown command” problem? Or do I need to re-install the program?
So far everything’s worked fine for me, never had any issues.
Just see what the repair process does for you. A complete uninstall/reinstall might be a good choice if repair doesn’t work. The real issue, however, would seem to be "why is some of the plugin directory missing? There’s probably many things that could have caused it that are easily avoided, but a big concern that would enter my train of thought is “is my hard drive (or SSD) going bad?”
Okay, will try. Thank you.
Hi -
The feature was implemented in the linetypes panel in Rhino 8 and is no longer a test command.
Hi -
Please run the Rhino SystemInfo
command and copy-paste the output here.
Rhino 9 SR0 2024-11-12 (Rhino WIP, 9.0.24317.12305, Git hash:master @ d48e3b25b763ba94ade005416a7d4461b016cedc)
License type: Commercial, build 2024-11-12
License details: Stand-Alone
Expires on: 2024-12-27
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.8
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 5-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.85
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-13-2024
Driver Version: 32.0.15.5585
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\Program Files\Rhino 9 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 9.0.24317.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.24317.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.24317.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.24317.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.24317.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.24317.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.24317.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Thanks for the SystemInfo.
I take it that you are trying to make a curve appear as the image you posted?
Did you assign a linetype with taper to the curve or its layer?
If you did and it doesn’t look like a tapered curve, please post a 3dm file that we can troubleshoot.
wim
thank you very much for your attention
and help
I found how to do it
Thank you
