In my line of work I regularly
to the left and the right.
Easy example of this would be a rectangle with rounded corners, that is 100x20mm long.
Its needs to be 150x20, so I would make a selection of all the control points left and move them using the gumball -25mm to the left, and +25 for the right side:
(because of the gumball orientation you need the negative value)
I think this is the easiest solution and also the most versetal. Other solutions like
_Extend dont work with multible object at the same time (?)
Scaled1 will break the fillets to Ellipses.
What slows me down currently is typing the value (-25) and 25 over and over again.
(or pressing Home, deleting the - and pressing enter)
Its there a way speed this process up? For example a Auto Hotkey script that you could easily run in the background. It would copy the selected value and return the negative value.
Does anyone els use a technic like this?
I cant write scripts yet
tnx
Martijn
