I have a box with rounded corners, open on top and bottom. I want to create a perforation pattern that wraps all the way around the box with equally spaced features. The first step is to create a point grid, but the surface UV curves are sized differently for each surface within the brep. How can I create one pattern with equal spacing around all the connected surfaces?
My instinct is to divide one edge into equal parts (the way a normal Divide Surface command would), find the length of the segments and use that number to drive the segment length across other surfaces, but that doesn’t seem to work. Any insight would be appreciated.
Equal Grid Across Surfaces.gh (19.6 KB)
