I’m not sure what’s going on with the EMap tool. The quality is much lower than it usually is or should be. I’m not sure if something else in the settings has something to do with this.
Hi Michael - can you post here or send the file to tech@mcneel.com to my attention? Please include a link back here in your comments.
Hi Pascal - I sent you a message containing the file.
Hi Michael - thanks - I could not see immediately in the images, where the problem is in the display but I get it now… the mesh you want to adjust is the analysis mesh that is used by Emap and other analysis commands - this is separate, becuse it usually needs to be set differently, from the normal display meshes.
That worked! Thanks @pascal! Not sure how it got changed on both V6 and V7, but that did it.
Hi Michael - that setting is file-specific - it is not global.
