Emap not working in Rhino 7 for windows?
For some reason, Emap is not working at all for me? Its very simple geometry. The dialog window opens but when I select the geometry, nothing happens and I cannot seem to find any settings for it?
I have the latest version of Rhino and a RTX 2070 graphics card
Thanks,
Rick
Is Zebra working?
A guess is Emap has lost the directory with the files
of the environmental maps.
Option command and under “Rhino options” select “Advanced”
Type “emap” in the text box and Enter
Are Emap analysis files listed similar to those in the image below?
Run the Rhino command SystemInfo and post the results here.
I found that emap or zebra in surface analysis is not working in Rhino 8. I have checked the directory with the environmental maps and the PGN files are all there. Anyone facing similar issues?
Run SystemInfo and post the results.
System info.txt (2.5 KB)
Are you in rendered mode? try shaded mode for emap and zebra.
I believe that is a bug that is fixed in 8.14 (upcoming)
Hi Kyle,
Thanks for your comment.
I was indeed in Rendered-mode… In Shaded-mode the E-map and Zebra surface analysis works fine!
Thank you so much!
grab it when it’s released in a week or so-
released as service release candidate. Released released in a month and a week (:
